Pictures please...
Returned that POC I bought on Ebay and found a PL400 WOPL. Bought it. Done! It gets delivered today. But I will certainly open it up and review that all of the White Oak parts are there. Thanks to everyone for their help.
Not on eBay. Waiting for it to be delivered, it was supposed to be today but...not yet.You found a 400 WOPL on ebay??? Or you found one from..........
looks good, gives a lot of meter selectionAnd mine are usually apart...
(I confess, I do have one pristine one actually put together that I listen to, but even that one was recently apart for some new surgery)
View attachment 45206View attachment 45207
New Rev C 400 light board which you can use a toggle switch to have 3 different meter sensitivity ranges and also able to adjust the brightness of the LED lampsmeter selection??? How
How about doing a WOPL faceplate in Army camo with Mil-Spec lettering, or maybe UAV stealth grey (I could get you some of that anti-radar reflective paint from the guys down at NAS JAX), probably only cost a tin of coffee. Everything cumshaw costs a tin of coffee.Maybe when I sell this last WOPL I am building, I'll find a 400 to play with. Hmmmmmm, Lime green, with purple laser etched face....![]()
http://www.jacksjoint.com/sailor_terminology.htm
Hi there, I’m new here and was pointed to this forum from WO. I have 2 PL400 in need of repair. Since you wouldn’t recommend going “full Monty” on the 400 (I’d agree) what would say would be the minimum bang for your buck upgrade you’d put into the PL400?Check with Joe, he may know if any of the builders have openings to get your amp done. I think me and Lee figured out that Parts alone were nearing $1000. Labor would be about 40-50 hours worth. I usually don't recommend pumping that much into a 400 when the parts are about the same for a 700B/II
You could easily have $1800 into a 400 and a 700B (if you have a core) would be not much more. It all comes down to selling in MY book. WOPL'd 400's don't go for nearly as much as a WOPL'd 700B/II and you'll get twice the power (500WPC RMS out of the 700). They are not cheap but for an amp that will last you a lifetime????
Joe, can you check that P/N again? I ordered (1) Mfr. #:100DP3T8B13M1QEH and received this:
I like the one in your picture better than this monkey-fisted switch, maybe Mouser pulled the wrong part?
