roccus
Thanks guys for the comments.... Got the T nuts installed on the baffles for the woofers and one baffle glued and screwed to the frame. The mounting screw holes on these rockville woofers are to small for 1/4-20 bolts so I will need to enlarge them. I was routing the last lewon piece when the bearing on the router bit sized up, cased a bit of damage to the baffle but will be easy to repair so need to get a new router bit to finish of routing the cab edges after it is all put together.
