Just bought a Soundcraftsman ae 2000..
#21
Would these be the photos of the backside of your AE2000?
Fishoz
Northeast Illinois
Always learning!
#22
Nice Nando...
That sparked me to take some of the day off (working from home) and clean up the Soundcraftsman someone left me and hook it up...I know it lights up but have no idea how it sounds. Also no idea how to hook up until now.
Never really liked colored sound...play everything flat but it’s a good time to try out.
#23
I don't presently use an equalizer in my system, but there is a case for using one when you want to achieve a flat frequency response in a room where furnishings, room size, speaker orientation have an effect on the sound. But, that means using an eq that has a microphone to receive a pink noise signal generated from the system and a built-in spectrum analyzer.
A dbx 20-20 is one such eq that comes to mind. I have a Sansui SE-9 that is simpler, but can do the same.
#24
I had one that did room analysis too years ago... Don't remember the brand, or what I did with it... But it had blue fluorescent display for each frequency and a rocker switch at the bottom of each to adjust them.
The display was both the "slider position" indicator and readout, depending on mode. It wasn't bad... Now I'm wondering where that went. Probably sold but I don't remember selling it.
#26
If anyone is in AZ I might be able to bring the 3 main components to you...Tucson, Phoenix is doable. And of course I'd pay for your expertise!
Bring the main components to do what with?? I'm down a couple miles south of Sierra Vista.
#27
I have an Audio Control analyzer that Ed gave me years ago. .with the mic..
#30
I just rebuilt that ADC EQ and after seeing the pain in the ass it is to hook in an EQ into the system (as cool as it was), I sold it this morning for $500
An amp (big), a tuner (Green) and a preamp is all you need. A Turn Table is a need also but the rest is just a pain.
#32
Tape deck!
#33
And open-reel deck. Each to his own. I've advanced way beyond a simple set-up. And it's been a long time since I turned on the analog FM tuner.
mr_rye89
Land of Entrapment
Lost in the Ozone Again
#34
The Adcom is a 500w/channel power amp. The only switch is the on/off toggle...
GFA-555? I have one.....broke it back in '13, needs that new NPN/PNP driver pair installed on one of the power amp boards.
Also welcome to Pheonix Audio Forums! I'm not a Zonie otherwise I'd come over.
#35
So the AE2000 is an EQ with a real time analyzer built in. You can flatten the room out and rather than actually listening to the music you end up constantly fuss with all of the controls because you can. I had a similar device years ago and found myslef trying to compensate for the recoding engineers mix for each record. For pro use it's a necessity for cavernous buildings etc.
62vauxhall
Southwest Kootenays BC
#36
Or each track in some cases.
