Mounting the outputs does get tedious doesn't it??
Yes, but when they click in place, it sure is satisfying.
2nd row in and tested. I think I may be listening to some music tomorrow!
The voltage trace was taken with a 10:1 probe so it is actually 100V/division. When I captured the image the scope was fresh out of the box and I hadn't learned how to set up probes yet. For $350 this 4 channel storage scope is a bargain. However I don't like it for looking at audio waveforms as the trace is to fat. Consequently I still have an analog scope for that. Also, anybody who wants to try looking at line voltages should be using isolated probes.Fantastic graph, But just to clarify the blue trace of voltage is 10v per division ? .... Am I reading 15 V ? Is the probe set @ -10 ?
Im relatively new to the scope setup....
M
yesIs this the proper replacement?
https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/MPSA42?qs=sGAEpiMZZMvAvBNgSS9LqryE/NQ9ZIJ3
Thank you. Got it ordered. Should be here Tuesday.
This represents 1/5 second...The AGC fuse protects the transformer and bridge rectifier. The smallest fuse that doesn't blow due to inrush current would be fine.
I have inserted a scope photo of the inrush current on a 700II. A 700B would be the same. The amp has 15,000uf caps. The yellow trace is the current at 50A/division. The bluish one is input voltage. Notice how the input voltage collapses at turn on. The peak current on the first cycle is just short of 150A. The voltage recovers after about 4 cycles. Now, is there any question why the switch could fail?
When the load goes up, the current ripple peaks will reappear. Load dependent. The caps are charged in a matter of ~64msec upon power up (about 4 line cycles)This represents 1/5 second...
Re: The yellow trace. With 15,000µf caps, is the ripple eventually eliminated completely, or is there any residual?
Good idea, but I’d rather see a higher voltage rating. 125v is probably good enough, but I wonder if a power surge from a lightning storm would overpower it.I like these Cornell Dubilier Quencharc RC networks across the power switch, and they are UL/CSA approved for across line use:
https://www.mouser.com/ProductDetail/539-104MACQRL150
I thought the same thing, and sure enough, they make one rated at 250VAC/600VDC, see here:Good idea, but I’d rather see a higher voltage rating. 125v is probably good enough, but I wonder if a power surge from a lightning storm would overpower it.
Put a big ass MOV across the line - neutral.I thought the same thing, and sure enough, they make one rated at 250VAC/600VDC, see here:
https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/254M06QD150?qs=/ha2pyFaduiT2OuLeU%2BQv17kdzKETcwFlKKKjZztZZnWBoPYez0xBQ==
But the one, above, rated at 250VAC does not comply with UL1414/CSA-C22.2 No. 1. Meaning is is not suitable for use "across the line" applications. I have never read those references, but I will download them and read them the next time I am suffering from acute insomnia.
With reference to a power surge from a lightning storm - From articles in Windpower Engineering & Development, we learn that lightning bolts carry from 5 kA to 200 kA and voltages vary from 40 kV to 120 kV. The outcome also is unpredictable—a strike that occurs a mile away can generate 70 V in electrical cables, and another can generate 10 kV from 160 yards away. So, no device can protect our precious audio devices from a direct or indirect hit.
The real purpose of these "Quencharc" devices is to protect the contacts of the power switch (or relay) from arcs, sparks, and transients to extend the operating life of these devices. If you are looking for protection from power surges, that is a different product. These come to mind:
https://www.bestbuy.com/site/audioq...rotector-black-silver/6320328.p?skuId=6320328
or,
https://www.techhive.com/article/3281455/apc-surgearrest-performance-p12u2-review.html
Finally, you can add the optimum surge protection inside the equipment yourself by installing (3) 130VAC Metal-Oxide Varistor (MOV) sacrificial devices across the AC lines, (1) from Line to Neutral, (1) from Neutral to Ground, and (1) from Line to Ground. These are good and new:
https://www.mouser.com/ProductDetail/Bourns/GMOV-20D131K?qs=sGAEpiMZZMuQmL5N8IqpX5jFkXwxQwBHR4M7hA/ej5U=
or
https://www.mouser.com/ProductDetail/Bourns/GMOV-14D131K?qs=sGAEpiMZZMuQmL5N8IqpX5jFkXwxQwBHlHxvukv%2BFo8=
Sorry for the long-winded explanation...
Yes it is Lee. Nothing can really protect against a lightning strike of any real magnitude.And then it's a crapshoot. I've had lightning literally blow up100hp pump panels. Lightning is a bassaaaaaaaad mo fo...
