Unwell Phase Linear 700 series II
There seems to be a discrepancy between my control board and the manual. I have an extra wire (purple) on my board that doesn't correspond to what is on the manual. It`s right between the white/red striped wire and the input ground wires. That is the same on both Left and Right channels.
Yes that is correct
the manual is for quasi complimentary
Attached is service doc
a new white wire goes to the old Violet and blue connection. The violet and blue reconnect to the transistor as on the attached
Here is connection for the color wires.
Yes that is correct
Thanks for that Grapplesaw:)
Now the only difference is the White/Red wires that I have and White only wire on the drawing, everything else seems ok.
I`ve traced the wires that lead from the control board to the back planes; this is what I came up with going from left to right:
Left Channel
Black* B- fused
White/Red * NPN column output transistor Base buss
Red* Collector of bias transistor
Blue* Base of NPN column driver
Black* Base of Bias transistor
Brown* Emitter of bottom NPN column output transistor
Orange* Collector buss NPN column/fused B+
Grey* NPN and PNP output transistor common emitter point
Yellow* Emitter of bottom PNP output transistor
Brown* Emitter of bias transistor
White/Red * Collector buss of PNP column/Fused B-
Purple* Base of PNP column driver
Grey* Input ground
Black* Input signal
Right channel
Red* B+Fused
White/Red* Base buss NPN column
Red* Collector of Bias transistor
Blue* Base of NPN column driver transistor
Brown* Emitter of bottom NPN transistor
Orange* Collector buss of NPN column/Fused B+
Grey* NPN and PNP output transistor common point
White* Chassis Ground
Brown* Emitter of Bias transistor
White/Red* Collector buss of PNP column/fused B-
Grey* Input ground
Red* Input Signal
Does that seem right?
Left Channel
Black* B- unfused
Grey* Input ground
Black* Input signal
Right channel
Red* B+
Grey* Input ground
Red* Input Signal
I am tied up right now and my wife will let me go.
here are the connections on the back plane. I think you may have a couple labeled wrong.
New control board installed (very nice btw). Backplane populated and all is good there, 0vdc offset both channels.
Left channel bias rock solid at 350mv however, I cant get more than .050v on the right channel board regardless of trimpot position.
Bias transistors were tested prior to being terminated on the new board.
Bias transistors were tested in-circuit and measure identically.
HELP!
Problem solved:
I forgot to replace the 1 amp rail fuses following the control board and transistor installation and start up :rolleyes:.... Those tests were conducted with the DBT and variac in line. When bypassed, the initial rush current must have popped the right channel B+ fuse.
Bias steady on both channels, DC offset immeasurable but the nice surprise is the power output, 421 wpc @ 8r (single channel driven) :)
Dare I try a 4 ohm load? Will the 5 amp rail fuses be up to the task I wonder.
Before you wrap it up totally Mike, you should ditch those CP-5 wirewounds in the Zoebel network and move to metal oxide to reduce the inductance. Inductance is self defeating in a Zoebel network.
Problem solved:
No. The 5 amp rail fuses will blow at around 600 watts per channel at 4 ohms..
Yep. And then you risk components when the high frequencies hit. 20 k at 770 watts at 4 ohms ain't happening..
