Yes that is correctThere seems to be a discrepancy between my control board and the manual. I have an extra wire (purple) on my board that doesn't correspond to what is on the manual. It`s right between the white/red striped wire and the input ground wires. That is the same on both Left and Right channels.
Here is connection for the color wires.There seems to be a discrepancy between my control board and the manual. I have an extra wire (purple) on my board that doesn't correspond to what is on the manual. It`s right between the white/red striped wire and the input ground wires. That is the same on both Left and Right channels.
Thanks for that GrapplesawYes that is correct
the manual is for quasi complimentary
Attached is service doc
a new white wire goes to the old Violet and blue connection. The violet and blue reconnect to the transistor as on the attached
I am tied up right now and my wife will let me go.I`ve traced the wires that lead from the control board to the back planes; this is what I came up with going from left to right:
Left Channel
Black* B- unfused
White/Red * NPN column output transistor Base buss
Red* Collector of bias transistor
Blue* Base of NPN column driver
Black* Base of Bias transistor
Brown* Emitter of bottom NPN column output transistor
Orange* Collector buss NPN column/fused B+
Grey* NPN and PNP output transistor common emitter point
Yellow* Emitter of bottom PNP output transistor
Brown* Emitter of bias transistor
White/Red * Collector buss of PNP column/Fused B-
Purple* Base of PNP column driver
Grey* Input ground
Black* Input signal
Right channel
Red* B+
White/Red* Base buss NPN column
Red* Collector of Bias transistor
Blue* Base of NPN column driver transistor
Brown* Emitter of bottom NPN transistor
Orange* Collector buss of NPN column/Fused B+
Grey* NPN and PNP output transistor common point
White* Chassis Ground
Brown* Emitter of Bias transistor
White/Red* Collector buss of PNP column/fused B-
Grey* Input ground
Red* Input Signal
Does that seem right?
. I think you may have a couple labeled wrong.
Problem solved:
I forgot to replace the 1 amp rail fuses following the control board and transistor installation and start up.... Those tests were conducted with the DBT and variac in line. When bypassed, the initial rush current must have popped the right channel B+ fuse.
Bias steady on both channels, DC offset immeasurable but the nice surprise is the power output, 421 wpc @ 8r (single channel driven)![]()
Dare I try a 4 ohm load? Will the 5 amp rail fuses be up to the task I wonder.
Will it be able to do 600wpc into 4 ohms?No. The 5 amp rail fuses will blow at around 600 watts per channel at 4 ohms..
OMG. What kind of rail fuses would support that kind of power,8 amps?Theoretically 770.
