grapplesaw
Vancouver
I am in a holding pattern till this is resolved. I did not want to finish the ac portion in case something profound comes up
BlueCrab
they are the most sensitive to RF interference (hum) because any induced RF EMF will be amplified along with the input signal.
I generally agree with the recommendations you give, but RF is defined as 20kHz to 300GHz. What's being coupled into Peter's system is AF - audio frequency - noise from the 60Hz AC line.
Peter - you can put a dead short across the audio input lines and do no harm.
Peter S
Ontario Canada
Hi Jim, I will try with pins 1 & 2 shorted, open, also with 1 K instead of 10 K.
IIRC, it was quite noisy with open inputs but I will check again.
Glen, I'm also hoping to leave the AC routing stock, but I am going to also try raising the control board and possibly ferrous shield above and below. I've been called crazy, might as well confirm it.
BlueCrab
Peter, in addition to raising the board, you should seriously consider the shielded twisted pair for the AC line, IMHO. This one change alone may give the biggest bang for the buck and it's much simpler than trying to shoehorn in a shield.
Peter S
Ontario Canada
The Shielded AC line option is still an option the I am considering. I just think it might be messy at the junction were the thermo wires come up to the lateral run at the top of the chassis?. I am going to spend a little elbow grease with some steel before I stress the AC wiring with un-soldering.
I do agree with you that it makes sense to shield the source of noise rather than the receiver, but I have a 'shoehorn' idea that is fairly simple.
I will post picks if I have any luck
Always good to shield the source.
BlueCrab
You can lead a horse to water...
Peter, one last try and then I'll keep my mouth shut.
First, what's so stressing about desoldering? Piece of cake if you have some solder wick and perhaps a solder sucker. About a 15 minute job and most of that is waiting for the iron to heat up.
Twisted pair shielded is really your best option - just sayin'. Buy some of that shield twisted pair recommended earlier - great stuff. Shielded twisted pair is likely to be smaller and easier to tuck than what you currently have. You only need to ground one end of the shield (actually that's best anyhow). You can run the ground for the shield to star ground point. Here's a picture:
Glad I got that off my chest - I'm starting to feel better.
grapplesaw
Vancouver
So here is my take on shielded power supply.
I got some #16 three twisted cable. It’s aircraft wire found on eBay #202655447995
I also add a thermal switch to turn fan on so use the trird wire to supply the fan circuit.
Lose wire just shows how you can pull wires through the shield.
grapplesaw
Vancouver
My question back to you is where are you taking the shield connection to. Cassis or AC input mains? I for one do not ground the chassis to AC input or service supply
BlueCrab
The chassis should work fine assuming it's connect to DC ground and may work even if it's not since there is significant capacitance to earth ground. Otherwise the ground between the power supply caps. Either will provide a low impedance return to AC.
Peter S
Ontario Canada
Hi Jim;
Sooner or later, I will need to 'drink the water'! I really appreciate the advice and I'm glad that your input is on record in this thread. When doing it 'my way' fails, as it usually does, I will finally have to do it "The right way". I had initially considered shielding the AC wires, but Henry Ott's book says that non-ferrous shielding has no effect on electromagnetic radiation, only electrostatic.
Admittedly, I believe the issue to be capacitive coupling between the AC hot wire and the control board, so copper shielding would help.
I am pursuing my crazy steel box for the control idea because of a (quite possibly hair-brained) theory that when the amp is driven harder and more current flows in Hot and Neutral AC lines, magnetic radiation will be more of an issue. Of course the hum would be harder to hear behind a large signal but still.........I could be all wet here.
Anyway, my steel box is half finished and it will work or I will toss it, and move on to your proven methods.
Thanks All, for your valuable help.....and patience.
PS; Test results to follow asap, but wife telling me to get some work done!
Hi Jim;
And....you're going to insulate that...right??
Peter S
Ontario Canada
I figured the steel shield would be grounded via the stand-offs. Is that not sufficient? I was also considering isolating one it from one of the mounting studs with plastic shims and a bushing, to avoid a possible loop? Thanks Lee, for any thoughts.
No I was being real basic about the component leads on the back of the board touching the steel box...
Peter S
Ontario Canada
I will make 6-32 x 1/2" tall stand-offs that would keep the board spaced from the steel. Is that what you are referring to? May take a little more than 1/2" , my board has the screw terminals for the bias transistors on the back. I think there there is still room before I start getting close to the meter pcb's.
I would line that steel box with a thin piece of insulation. I would be REAL leery of relying on space only to keep the back of the driver board from shorting out against steel box.
Peter S
Ontario Canada
Thanks Lee, I have some thin insulation that could serve the purpose.
I think I'm onto something!--positive results;
I believe Jim wanted know results with input shorted rather than 10 k.
Customer at the door so no time to enter data BUT------the shield on the bottom completely fixed the issue on the right chan, 60% better on the left chan.
Planning to test with a cover on the box
Of course, you are technically correct. But, what we have here is 60Hz hum "radiating" through space to another wire or component. Spare us the nomenclature about frequency bands, the effect we are talking about is RF as in radiated AC signal, (transmitter and receiver) thus RF. If it were conducted as in wired AC signal or inducted as in wired DC signal, (microphone and speaker), thus AF. So, no.
