Phase Linear 700B series II meter issues
#23
I have not yet had a chance to open it up, when I do I'll try to post some pic's of the inside. Get some voltage readings.
One more thing with it is, a after turning it off, there is a thump through the speakers about 10 seconds after, and another about 4 second's after that, then is quiet.
Turn Off Thumps are common till rebuilt, or upgraded. The manual tells you where to look have you read the manual yet??? You need to.
#26
Section 5-8 tells you about the display and where to start troubleshooting. (In the 700 Series II manual, Not the 700B Series II manual)
eykensf
Belgium
Hi, You have 2 boards for the LED VU (PL 37 DISPLAY A and B) : one for left (B)and one for right (A). The right board is (has) the power supply for the 2 LED VU (there is 12 VAC coming from the big transformer) and on that board there are 4 diodes and one electrolytic capacitor (DISPLAY A). I think one or more diodes on that board are broken or the capacitor is broken. The two PL 37 boards are acting the same, so that is a power supply issue on the LED board : diodes are 1N4004 and capacitor is a axial electrolytic 470 uF/25V. Greetz, Flip
stuwee
Deep in the Sonoran Desert SW
#28
I'm a meter freak, while yours is not acting properly, I like how it moves it's pretty cool, you only need to watch your levels depending your speakers.
I hate the meters on my big SAE, then they put out the even bigger 2hp all the info you need ! Puts MacIntosh big blues in the shade ;)
#30
Mac builds some big amps, you looked lately?
