I hope the attached file makes it clearer.
Left to Right :
1.13/80.5/0.58///-0.7/-0.08/0.08/// 0.67/80/0.66///-1.2/-0.66/-0.66
Thank you !
Belay that order, Right channel base wire had come off. I can now bias both channels to 0.0375V , which is a factor 10 short. But the same on both channels.
I swear this thing is haunted. Remember : the left channel was solid at 375 mV, the right was zilch.
I started hunting for solder shorts but found none. What bothered me was the high resistance (250+K) over D13, which I would suspect over a bare diode, but not here. The other side was 12K which is the resistance of R13 before it.
I found R39 (1 Ohm) to be 1.7K, and R37 (22.1 Ohm) at 0.7 M (yes, Meg). I measured the rest, looked OK, and pluged it in.
The Left channel (previously OK) now puts out 0.035V (/10) and the right, previously dead, 20V.
I'm going cuckoo.
Peter
Yes Gepetto, of course I did. Original resistance and wattage. Even the same brand
Decided to do a quick remeasure :
Previously witn L channel biased 375 mV
Now
1.14/79/0.58 ///-0.7/-0.08/-0.08///1.18/80/0.6///-0.7/-0.08/-0.08
EDIT : the biases I'd set to 37.5 mV yesterday are holding
15V+/- is good.
Bias transistor C-E 2V both channels
Yeah, we're it not bias in both channels is a factor 10 too low. Can't get it up, so to speak.
Peter is being humorous tonight. He cannot get the bias to dial up and he made the joke about other things that can't get up![]()
