RevE5 vs RevG5?
Artied2
Jax, FL
Jax, FL
Hi all. I notice on the price list a RevG5 control board, but see no info about it. So, what is the G5 mod? Thanks.
Also, is there any advantage to upgrading the TO-3 sockets to something better?
Artie
Artie
I believe G board is Dual Mono
TO-3 can be replaced with WO back planes. Big advantage
Artied2
Jax, FL
Jax, FL
Dual mono! Super cool. This is just what I was hoping for. I wish they had pics.
Thanks NW.
Artie
You are on the right path. The old stuff is an accident waiting to happen. Joe (White Oak Audio Design), has the answer to smoke and flames and insurance claims.
Yeah. I bet they're going to make me pay for it. :p
(All kidding aside, I will.)
Well worth it for an amp (done correctly), that will last you the rest of your life. All that for $600-$900 in parts....... And that's for EVERYTHING!!!!
Artied2
Jax, FL
Jax, FL
I already have the "basket-case" 400 II. For my first attempt, I should probably keep this simple, and play "by the book", so to speak.
Edit: When I say "first attempt", I mean at modding this amp. I have over half a century of electronics experience.
It cost the same to do a 700 as it does to do a 400 (check White Oak web site) and then the 400 is worth nothing (check ebay). Sell the 400 and use it to get into a 700B/Series II.... It will be good to go for the rest of your life and should you need to sell, it will still be worth $1500-$2000.....
With the ON Semiconductor MJ21195G and MJ21196G outputs installed, you basically have a PL Dual 500. I would have no problem claiming that they are similar in concept, with the WOPL being significantly better in terms of reliability and specifications.
Did the PL Dual 500 use the same transformer as the PL 700 Series II, just inside?
HUH???? Are we on the same conversation?
