The Smoked 400
#63
Yes please, measure with D9/10 lifted. You don't want to worry about that piece of the circuit until you get the main loop working, which it is not presently.
#64
31 volts on the rails, Q10 gets instantly hot, I mean finger burnin hot, 12.37 volts on Q4 base, 19.38 on Q5 collector, didn't get a 6L,R measurement , gotta cool it down,.
Australia
#67
Best entertainment I have had all day, looking forward to progress Lee :)
Australia
#69
Glad to provide a respite from your trials and tribulations Darc!!
Its interesting watching the specifics like what you test and the path of fault finding. I do that to some extent with my job, more so with upgrading my nak decks.
#71
I am about ready to resume troubleshooting on my WOPL 400, but I need (4) of those RCA 66546 or RCA 410 drivers.
You really only need 2 Mark. The 2nd and 4th column starting at the transformer and ending at the output binding posts. These are the quasi columns. The first and third don’t care.
#74
Joe,
Pad 6L, 6R are at -23.80 volts with pad 12 voltage at -28.5....That with the variac at 100%...
#75
with those readings Lee, looking more and more like you fried Q7. Have you checked C-E for short with your DMM?
#79
I believe so Joe, it got hot enough. Why did Q7L go? Zapped through the power supply?
#80
Out of circuit , same result. Should I reattach the free end of R76 before applying power w3ith new Q7?
For some reason didn't check C-E in circuit, just B-C, B-E and reverse polarity...jeez..
