- Jan 14, 2011
- Gillette, Wyo.
Thank You Sir Joe, always appreciate your engineering expertise!
Fred, I figured I had 600.00 per set in em. Kinda pricey.
Amen Joe...
Shit Fred, I was gonna go halfsies...
I wonder what’s being laser cut? That’s typically charged by the inch. The outside dimensions could be sheared, holes drilled with a dedicated template then bent in a break...For Joe: copper can be water jet cut and that is typically cheaper than laser.
We have a guy locally who is very inexpensive. I need to check with him on cutting carbon fiber woven sheet and ceramics, but I think he can.
You might want to check around- that may reduce the cost of copper; might also reduce the cost of the aluminum ones I presume you offer...
Now that would surely cause a shift to an alternate timeline the likes unimaginable by the tools at CERN. Shit! There’s some guys in black suits at the door!Shpongle colliding superconductor...
