- Jan 14, 2011
- Gillette, Wyo.
4 ohms should be around 340 or so...
With a fresh WOPL build, you could tell us...
So if I use 4 ohm speakers it would be like getting free horse power compared to 8 ohm then right?? I have all the pieces cut for the stands for the altec cabs the casters should be here this coming week. I have the wopl 400 driving the 15" mids and the stock 400 driving 18" subs... I find it interesting that the wopl 400 runs warmer driving the mids than the stock 400 driving the subs. I always though an amp driving bass works much harder than an amp driving higher frequencies. I know the meters on these amps don't mean a lot but the meters on the wopl are not hitting in the red area of the meter while the stock amp driving the subs is plowing into the red zone a lot almost every bass note when I have the volume cranked up. The wopl 400 seems to be doing good after the fatal melt down and what ever was causing the DCP to trip when cranked up seems to have been resolved after the repair4 ohms should be around 340 or so...
Many components in the right channel got fried including most all the right channel output transistors.....Pray tell, which repair...
Ouch!Many components in the right channel got fried including most all the right channel output transistors.....
My stock 400 did the same, needles right and cool as a cucumber. Never had a WOPL to compare it to. My amp never seemed to break a sweat no matter how long I ran it or what I had it hooked to. It is a series 2 400. I always wondered what was going on as a lot of others say those amps get really hot at a 4 ohm load. Mine never did and sometimes running it with some very hungry speakers. It's good to know your WOPL is doing well. I still need to jump back on the 700 to finish it up. We will see. Still want to hear your set up.So if I use 4 ohm speakers it would be like getting free horse power compared to 8 ohm then right?? I have all the pieces cut for the stands for the altec cabs the casters should be here this coming week. I have the wopl 400 driving the 15" mids and the stock 400 driving 18" subs... I find it interesting that the wopl 400 runs warmer driving the mids than the stock 400 driving the subs. I always though an amp driving bass works much harder than an amp driving higher frequencies. I know the meters on these amps don't mean a lot but the meters on the wopl are not hitting in the red area of the meter while the stock amp driving the subs is plowing into the red zone a lot almost every bass note when I have the volume cranked up. The wopl 400 seems to be doing good after the fatal melt down and what ever was causing the DCP to trip when cranked up seems to have been resolved after the repair
 I really am enjoying the new speakers,  a lot more clarity and depth, my old speakers sounded a bit flat at low volume levels they love power but these sound good no matter what volume I am at. Pretty awesome.... theme from pink panther when both PL's pegging out in the red lol
 I really am enjoying the new speakers,  a lot more clarity and depth, my old speakers sounded a bit flat at low volume levels they love power but these sound good no matter what volume I am at. Pretty awesome.... theme from pink panther when both PL's pegging out in the red lolAt Mach 8...Moby--- "Play" track 4 is killer.
Crystal Method--"Vegas" track 4
Are You Shpongled--track 6
Standard amp test tunes at my.place...
Don't think I have ever heard of any of those Lee...Moby--- "Play" track 4 is killer.
