grapplesaw
Warbledauber??  I like a good burger. Will it cook that??!
			Are there any transistor covers out there for a 700 Series Two that anyone knows of?
Or... just keep my fingers away from the back when it’s turned on?
Me tooI got a dozen sitting here gathering dust. I don't put them back on since they hold heat in. Heat is our enemy
Well, then...They create a heat envelope and, although I never took measurements, I'll bet it raises the temp 10-20 degrees. The heat sinks would be the only way to wick that heat out of there and it is really inefficient compared to using a small fan to shooooo it awayyyyyyy
From 8U to 21U:Mark,
What was the item number or description for the rack you ordered from Amazon? I can't find it.... I'd like one taller to fit more amps, but I like the look. Good find!!
Didn’t order the shelves yet. Nor the power strip or the exhaust fan.Thanks Mark....I am researching and may buy the same rack. Any advice?? Did you order the shelves for the rack?
