I'm sure glad I got the Phoenix connectors for the PL14_20. I've had that board in and out and back in about 4 times. After rebuilding the back wall I reinstalled it once again and setup for the power up procedure. I setup the variac and DBT and flipped the switches... At about 60 VAC where I initially ran into issues there were no problems
. When I got to about ~90 the DBT light started glowing and at ~100VAC the DCP relay kicked in
. I added the new MJ21196's a row at a time without any issues. After adding the last row and having no issues I went on full line voltage and everything worked fine. The bias for each channel was at about 220 mV with the pots fully CCW. I set both to about 350 mV turning each pot to about the 1:00 position. I need to re-attach the face place and get some tunes running through it.
