- Jan 14, 2011
- Gillette, Wyo.
Check output transistor case toground..
A couple of questions / concerns about possible cause of this overcurrent situation.
*would loosing connections with one of the back wall thermal transistors be a source? When fiddling with the heatsinks there was a lot of stress put on those connections. At least once I lost my hold on the WOA board and that connection got a yank. What is the recommended replacement if this is the case?
*I have a concern about Q3, 4,5L and also the right side. The left side probably got a little over heated when I put them in backwards (never powered this way). Both the left and right have got flexed several times with the heatsinks sticking up so high. Could their little chain of three cause this if one were bad or have a crack in a lead?
*I kept asking about disconnecting power to the WOA board just to see if removing it from the equation would allow proper DBT operation.
*none of the TO220 transistors, that have heatsinks, have any sort of insulation from the pcb. Just want to make sure this is correct.
*I'm going to go through the BOM an make sure that there are no errors in parts placement.
