I recently acquired one in need of repair and need some guidance. With a DBT in circuit turned power on bulb not dim but not very bright. I removed all outputs and found 1 that was bad. reinstalled 6 good transistors. The r and l amps board had 1 burnt resistor and several others that had been very hot at one time r213 was burned badly. I also replaced other components that had gotten very hot R213, r113, r 115, r215, r103, r203,. After this hooked up cd and no movement from left or right LED gain knobs. Actually right gain knob LED illumination is stuck in the middle. Ideas thanks.
