WOPL dual 500
#82
When you up the capacitance, it just doesn't work. Plus they were dealing with 20 amp BR's....
#83
Man Glen, I am so happy for you. You nailed it and have one helluva amp CONGRATS!!!!!!!!!!!!!!!!
grapplesaw
Vancouver
Looks good to go. Bought some 10 Ana 15 amp slow blow Fuses today. So fired up with a 10 amp fuse and all ok. Thanks Lee
Jer Jer KK6AC
#89
I have a Dual 500 that I am planning on upgrading. This will take some time as I have alot going on in my life (retired... LOL!). I will need to purchase alot of material for the rebuild. Really thinking about redesigning the backplane (via a schematic and one of those doit yourself circuit board online sites), it is an atrocious hodgepodge of point to point.
Anyway Glen, I am being told you are the Garu of 500s. If you have any pointers, that sure would be appreciated. I need to check one of the boards I built for my 700 Series II and 400 Series II to see if it is what is mentioned above (I have not upgraded these amps yet).
BTW, I also have a Carver C500 and want to go thru and upgrade, clean up it's wiring as well.
Jer Jer KK6AC
#90
I looked at my Dual 500 today and I know this would be a great task to make a PCB back plane. Still debating on that. I see ferret beads, I believe this is to suppress parasitic oscillations and no wonder with how this amp (along with the rest of Phase Linear amps) is wired. No disrespect, I love PL, I have had them since 1978. They know what they are doing, just I think they could have done a better job wiring these amps.
If I did a PCB back plane, I would definitely do a double sided clad board. I believe this would eliminate the need for the ferrite beads.
Again, all this is preliminary and it is almost daunting to me. So I may not go that route. Just looking into preliminary and what I want to do.
Also, I will separate the inputs / power from the rest of the wiring as I do not believe in grouping these things together (power etc.)
