P.L.F.
- Sep 9, 2012
- Poland, Warsaw (Central Europe)
- I love BIG amplifiers!
From time to time one can find Carver C-500 amps on sale (here is a fine example of the amp -> https://youtu.be/LdySAN72XSM). It looks similar to a PL400II, but with more power at least on specs. There is also extra output transistor per bank (4 instead of 3), so more like PL700II backplane dimensions? The C-500 driver board is however visibly different from PL-36.
Apparently VAS works hotter vs PL400II. Higher voltage was implemented to expand bandwidth and increase slew rate. The PCB had as well DC in / speakers out protection circuit built in. The other key different feature in compare to PL400II was the fact that Carver C-500 was ‘internally phase-inverted’ in one channel allowing bridged operation, so you could run it mono (500W) just by using the two red / white posts, provided speakers’ impedance was watched and cooling present. Power outputs were normally marked as C1000 - not sure what they really are. On the pics attached, there are MJ15011, quasi topology. That gear could have been repaired.
The amp looks like WOPL upgrade ready. Does anybody have this model to check dimensions and spacing requirements? All in all it could be an additional power amplifier with WOA upgrade available, well maybe without the bridging option…
Your views?
Your views?
