grapplesaw
Vancouver
Bias increase with heat right
So the bias voltage increases with heat. Not sure how that reduces heat in an amp. I thought the bias voltage would dropped as thing get hotter
Bias in a solid state amp should decrease when the output stages increase in heat.
The base-emitter junction turn on voltage of NPN devices decreases as they get hotter so it is necessary to DROP the bias as the output stage heats up. If this does not occur then runaway occurs and blows fuses as you have seen.
Also bias in the .46 range is in the danger zone. That is dangerously close to the turn on voltage of a hot output semiconductor. You need to bring the maximum bias down to the 0.35-0.38V range.
Eyeh .9 volts
is it worth testing bias transistor or just change it and the 180 ohm resistor on the first driver?.
I moved to 150 ohms in the first predriver position long ago. That is not your problem but that is my recommendation regardless.
So.......with no load and no input, if you heat the bias transistor the bias voltage will drop??
Yes, that is the way it is supposed to work. The bias transistor servos to the temperature of the output devices. The output devices lead since they are the source of the heat but the bias transistor is supposed to pick up that heat and dial down the bias as the outputs get hotter.
Hard to tell that when the amp is loaded cause the load drives the bias up correct??
grapplesaw
Vancouver
So we set bias with not load on input and no output to say .350volts after heat up time is stable.
Now after connecting light input voltage and 8 ohm dummy the biass instantly jumps up to say .4 volts and as time goes on it continues to rise. Should this happen? Is there a threshold where it will actually start to go down?
That should not happen Glenn.
Ok that is what I thought. So now to find what is causing this. First thing I will replace the bias transistors but that is not it. It's strange isn't it
Does your D500 have the bias transistor thermally coupled to the heatsinks?
Joe, every amp I've ever tested , the bias jumps as soon as I turn on the generators, what I haven't done is wait and see when the bias starts dialing down...
As I stated Lee, the bias servo lags the heat in the outputs as the heat has to conduct from the outputs and into the bias transistor.
grapplesaw
Vancouver
I agree with you on max bias voltage. The manual goes as far as .6 volts (. Scary) see attached
grapplesaw
Vancouver
RIP runaway bias dual 500
Thanks for your ideas along the way on this problem
it has got to a point to which l as sorry to say but the project has become to
much for me so I have gone ahead and crushed the beast in my new 150 ton press
Off to the scrap yard with it then
Not!!!
here is the latest
first the thing goes critical as it heats up
it crashes more now than when I got it because I am messing with it
last night I changed out the Bias transistors and the 10 ohm and 180 ohm on th the backplate
guess what I found
one 10 ohm on the left channel was a cold solder and as I wiggled it to remove saw it moved.
So do I have replaced both channel 10 and 180 ohm resistors along with new 5088 bias transistors and am heating it at this time
fingers crossed and with suspicion of some sort of heat up problem this may be it
i will update soon
