grapplesaw
Ron that's across them160 volts at the rails?
Fuck yeah Bro, bring the thunder
80 volts each at low and 120 at high
I am beginning to think it is spikes on the input from static in the test equipment pots. Maybe I am pussy footing around with small fuses but when you hear it run away now twice I am walking slowly. At low power sine is clean of oscillations. Just letting run a bitStill have an oscillation eh??
I just wanted to check that possibility. Lee you will be happy to here it dose not. I am hear to tell one and all the Audio Precision is one hell of a peice of equipment.The AP has noisy pots??
Potentially that is correct Ron. Fortunately I have loaded smaller rail fuses to prevent a catastrophe from happening.So is a runaway amp like a runaway diesel? Just goes uncontrolled full output until it blows?
Just getting back to the runaway beast. It is stable but will blow rail fuses without any input or output connected. Lee has sujested a latch up somewhere. The 500 has the following differences on the backplate.
.39 ohm emitter resistors
only .05 uf caps on the rails to ground (700 has .33)
there are no fly back diodes
I have changed the power caps as the capacities were different on the ones it came with (15,000 and 18,00- which measured about 21,000 , to balanced 15,000 ones and will try first that change up.
Any my comments on fly back diodes anyone?
Ok I will replace itDoubtful flyback diodes are your cause Glenn. Zoebel network??
I resoldered the underside of the board looking for such.Broken trace?
Here is 25kGot the same look at 20K??
Here is 25k
There re is a 4558 dual opamp in the centr of the board it is the high Fequecy attenuator to guard again feed back
its output is common to both 356 op amps input
here is the dicription of protection system and how it is built.
