Updated crash report. From today test
High frequecy curcuit removed
2k signal steady at 4 volts out into 8 ohms
two tests
first crashed at about 18 minutes run time
second started 3 minutes later. And ran only 10 min
heat seams to be low but maybe the root of issue.
Results
7:52 start2k
4 volts out
.110 volts in
.4688mv bias
Right
.65mv out
.374mv bias
Temp 77 F start both
5 min run time temp 82 .0701% N THD
10 min run time temp 89.5 left 80 right .0709 N THD
Left bias .4635. Right bias .379
Left out 4 volts Right output .634 mv
153.6 rail voltage
15 min run time temp 90.4 left 83.5 right .070 N THD
Left bias .4616 Right bias .376
153.2 rail voltage
16 minutes in crash occurred !!!!
Temp on heat sink at crash
92 deg left
85 deg right
Blown fuse Positive fuse 4 amp buss 250v
23 min in restart
Temp 88 left 85 right
.0839N THD
Left bias .449 Right bias .339
153.6 rail voltage
5 min 92.8 left 86 right .0752 N THD
Left bias .455 Right bias .360
154 rail voltage
10 min crash positive fuse again
so is it ic lf356 or driver positive rail?? Ideas anyone
