winter makes it worse, darker earlier... Depressing.
Mouser stock the eom switchcraft washers for a little less in price. I will put up the part numbers when I get home
Tell me where I go wrong -780 ready to ship ( if you buy them all I want some)
http://www.mouser.com/ProductDetail...=/ha2pyFaduhE2UrRYjkc5Uqfmx/s543cID/WO35EHOg=
Your WelcomeYup, thanks Glen, that has the 10mm footprint needed.
Use a 1uF polypropylene non polar. Do not use a polar in that application. Wima makes many suitable caps for this applicationLOOKING FOR:
The AC back panel "fan only" outlet for the WOA 700 chassis. Not sure what this thing is called. Mouser doesn't have many pictures in their AC outlet page, can't identify what I need.
ALSO:
The "Direct Connect / Normal" switch states a .47µf capacitor (16v should do?) and a 220kΩ resistor (1/2 watt?). Recommendations for these parts?
I just happen to have a few! Thanks!Use a 1uF polypropylene non polar. Do not use a polar in that application. Wima makes many suitable caps for this application
