roccus
Sounds like your DCP is working fine, I wouldn't remove it.
I am sure you will figure it out, once you get the 8 ohm dummy load see if you can duplicate the shutdown at will. Run the amp at different frequencies from the tone generator from your PC, and also at different levels.
Stick with it you will get it.
yes something somewhere is leaking out DC now and then.. it shut down again I turned the volume down and plugged a TT into the preamp and click had to turn off to reset it
