- Jan 14, 2011
- Gillette, Wyo.
1 to 2 would be nice....
All I have is a DMM, an oscope and an app to send signals from my laptop but it wont put any voltage out... anyone here have a signal generator they will part with??
Check the output with the scope as well to check for distortions. These may put out the higher voltage but no always clean signalSome sound cards cannot put out more than 1 volt. Check the spec on this for your sound card. You will need up-to 1.75 volts to drive it. Just a cautionary note. I had issues with a sound blaster card doing this.
Your computer does output voltage, it is measured in AC peak to peak, I believe you need close to 2 volts peak/peak to drive the phase linears to full boogie. The more you turn the volume up on your computer the more you drive the amp.
Your computer probably does not output 2 volts pek/peak, but may have enough output from your computer to drive your amp to where the problem surfaces.
So use your computer to drive the inputs of the amp, then watch the outputs with a scope with nothing connected to them (no load).
Lee can step you through this, if you need an 8 ohm load for testing they are available on ebay for short money.
Ok guys, sorry I've been awol on this one.
My test set for the 400 boards includes a BGW 750 module that I drive with a HP204C oscillator. The oscillator will go down to about 3 hz. The test set has switches so that I can drive either input to the board. I test the contacts with a Dale 250W/8 ohm resistor on the output of the board and watch it on a scope. The board trips around 5-7HZ with the BGW clipping at around 35VAC RMS. After it trips at sub audio frequencies I then drive the BGW across the audio band to make sure it won't trip at audio frequencies.
Anything is possible, including a DCP that is acting up, but this sounds to me like the board is doing what it's supposed to which is disconnect the output in the presence of very low frequencies including DC.
I've seen receivers that tripped at low bass which I assume is intentional by the mfr to protect the amp. The intent of the DCP is to stay out of the way and only trip if the amp fails.
Yea, I've been on the road probably as much this year as ever. It is hard to keep up. I try to scan the emails when I have a chance. Heading to Bahrain/Dammam Saudi Arabia tomorrow.
Good work Ray, ya been rompin on it ????
Damn Don, I knew you went around the country, now you're going around the world??
