- Jan 14, 2011
- Gillette, Wyo.
Sounds like a decent plan...is it running hot at all??
I'm not very fond of just throwing parts at a problem. The most likely thing to happen by changing C7 is the board gets damaged. If anything verify it is the correct value. R3,4,5 should be 56K.
R3,4,5 have 56.20K 1% resistors in there....
Lee sitting on my bench I don't have a fan on it it runs cool as a cucumber at low and moderate volume but when I crank (meters running in red a lot) it up it does run hot but with a fan on it it runs fairly cool
Yes I put a record on and crank it up then I hear the clicking snapping kind of noise come out of the speakers and see the LED's flicker when it cuts outI think Don was right and yo u might have a subsonic transient. Is the turntable running??
OK I will have a look at those... it has now been running for 3 days at all volumes and has not shut down so out of 100+ hours of running over the past few weeks it it has only shut down 2 times and when it did it was not cranking it was at moderate volume one last thing I will try when my load resistors get here is load the crap out of it as some here have suggested and see if I can get it to trip and maybe find a pattern that trips it then maybe I can get to the bottom of it
That won't do shit. Who suggested that????
Yer grasping at straws. Might as well unhook the speakers.
I did , for one. A loaded amp acts a whole lot different than an unloaded one...
I makes sense to me with a load your working the components without a load it would seem your just pushing air
Guess I'm just a bull in a china shop
It does... But "Load the Crap out of it" ????? Makes no sense
I'm sure he is Ron but you have followed this whole build from start to now and have seen the conflicting advice I have gotten here and there I understand that everyone does things a little different and giving their honest opinion and I really do appreciate their input very much they are trying to help but it is hard to help without having the unit in front of them and I get that at this point I am willing to try anything. But I think what gets lost is previous posts on where I have been with this I have tried to be detailed and when I think I have found something turns out it does not pan out for instance yesterday I thought I had found a way to get the problem to reproduce and I think all will agree if you can't get the problem to reproduce you can not fix a problem you can not find it's like if you hear a noise in your car and go to a mechanic and the noise stops the mechanic can not tell you what is wrong or know where to look if the noise is not there when he listens to it.Perry is good people and one hell of a tech Ray, maybe between the both of you this issue will be figured out
