Here is how to download and play the files, save the .bmp files to make your own CD card with titles.
First of all, all the MP3s were created at 320 kbps so the files will be LARGE but tops in quality that I can do with the Audacity program. Whether it came from a CD or You Tube rip it was processed to remove clipping (and boy howdy! You would be surprised at the amount of clipping crap can occurs and the audio still sounds 'nice'). Reverb and equalization if needed then normalized in most cases to bring the levels back up to good levels without making it clip a ton again (and that can be hard, plus EQ settings can push a file over the edge if one isn't careful) and again saving it at 320.
Now, to download, visit Dropbox at
https://www.dropbox.com/sh/sbztvarjg8m3b1j/AADuwN5KuMM8gdy--FGaNvjKa?dl=0
You do not have to sign up or sign in to download and just click the Download link at the top right corner and choose Direct download and clink then choose to save to your computer when it asks you what to do with the ZIP folder it's going to send you.
Usually you can play a ZIP file without extracting it in Windows, others? and to complete the transfer you need to extract the files, there is a link in the folder in Windows to do just that.
They will be extracted and expanded to full size again in a new folder and that's what you need to play them in your media player or burn them to a CD or even tape them if your wish (although the program is around 4 minutes lone so it's too big for a C-60). You can do what you like to put them on a personal player or whatever at that point...
There are two .bmp files with the tracks listed and timed and you can print them make a CD card on your printer if you have a template or your word processor does. or trial and error, look it up, a CD insert is around 5+ inches square when folded and first vertically on a piece of printer paper. the trick being to feed it correctly so both sides are together that right side up...
Or just burn the CD and label it.
Now you have a month's time to enjoy it and to amply praise Fitz43/Doug for giving up the storage.
And with that, my Elfin duties should be done for the year now unless there are still questions.
ENJOY!
