New to me PL400
There is only 2 of the RCA's, nice sil pads on them. I guess the ON ones are the Peavey one's Joe mentioned. Are they close to a 410? What the NEC's? Equivalents to the 909's?
I was planning on ordering heat sink compound from PE since I'm ordering a few other things anyway, but they are out. Is there any real difference or will the Ebay stuff work the same? How much does it usually take to do all 16? I dont want to grill the outputs as soon as I get them installed. In case you guys didn't notice yet, I build NFL goalposts and run mills and lathes for a living. I'm somewhat dense when it comes to this. But, I'm gonna learn as I go. I'm stubborn that way.:violent1:
It takes mills and lathes to build a goalpost?
Sil-pads don't require grease....
In fact, you have to clean off the old grease from the heatsink before you use the Sil-Pads. 90% isopropyl takes it right off.
You have no Idea. Goalposts have over 20 hand machined separate components milled to a few thousandths of an inch tolerance. Quite a complicated process. We set whole crossbars on a poor little Bridgeport with an overhead crane all day long. I build all kinds of cool little parts for all kinds of things... then I come home and crank out some music.:headbang: I love my job. Thank you for the info.
You and I have an altogether different idea about what " takes it right off" means....
We have a few Bridgeports ourself....
We also have a couple Trak cnc mills. I love running these machines.We're getting a state of the art Fryer tomorrow. I'm psyched.... I'll have access to the laser soon and If all goes well with this project want to make a laser cut/etched Stainless faceplate.
Fryer????
Vertical mill with tool changer. I have yet to see it, and I'm getting a crash course on programming it. From what I'm told, nothing like the Bridgeports or Trak. With any luck, I won't crash it in the crash course. We'll see. No guts, no glory.
Ah, CNC vertical, gotcha. We bough an Okuma CNC years ago and finally got it running last week. The oil galleys in the toolhead were plugged....
What about a little brake cleaner on a rag?
One thing I haven't tried. What works best for me is good ol wellhead condensate from the oilfields. Just spray that shit on and the grease runs....
Brake cleaner is my go to when all else fails. Sounds like you like your job also. I get dirty and bust my ass, use my head, and create solutions. Don't get much better. Plus I have access to machines to make anything I want.
