nadude98
Damn, and I just got married.... tsk tsk NavLinear
Yep, and now it's tme to check the resistors on the BACKPLANES.......
I meant to say:
Yes, and I also checked the resistors that Joe had me check on the 14_20. I have checked and rechecked the backplanes.....![]()
Now is when a scope would be handy....
Is that a White Oak cap kit??
We haven't forgot ya...have you reversed the cables coming from the pre amp to make sure it's not the pre?? It might be a good idea to check for DC on the pre amp outputs.
Do you have a PL service manual? If you do read the part on " Current Sharing test". WE can root out a leaky output with that test, without a scope...
Ok, I was reading it. I have a couple of load resistors but they are only 10 watt IIRC. Next I am supposed to drive the channel with 200 Hz input to achieve 40v rms. I don't have a signal generator. How should I go about doing that, and will my load resistors suffice?
I never mentioned this but there is a little bit of a turnoff or turnon thump? I think it's left channel. I will have to check that again. Never really paid attention because it had always had that.
Been distracting myself with a Pioneer A60 amp I'm restoring for the living room...
No, 10 watts won't get ya off the porch........I use to get my homebuilt 200 watters pretty hot during this test.....
