Your leads are not measuring R38, or R39. You are measuring a diode. Chang, if you do not know the difference between a diode and a resistor, you need to learn on something other than a Phase Linear 400. If you have shorted something on the backwall transistors the least you have done is popped a fuse, and at the worst you've shorted a couple outputs and possibly some components on the driver board.
Resistors have color codes on them, not a diode symbol. R38, R39 are the Brown, black, black, silver (10ohm, 1/2 watt) that goes from where your black lead is to the base bus bar....
