Looking for a working early PL 400 Control board
#41
And then stops or just spins?
Hoping the PO did not put too long a screw in there and jammed it into the windings of the transformer. Well your fuse test should tell you that.
It got tight coming out at the very end, looks like 3/4" screw
#42
That is the original screw. Those self tapping screws get the last threads near the tip clogged with the zinc die casting which is why it was harder backing it out.
#43
I have a 8A 250V fastblo in the line now. Does the bussbar have to be isolated from the chassis before I plug this in? All the other wires that come off the tranny are still attached to the main ground between the fins
#44
You should be fine with the 2 main outputs wire nutted off as you have.
Now with your handy dandy meter you should also be able to check out the bridge rectifier by using the diode scale on the meter selector switch.
#46
Black meter lead in the COM meter input, red meter lead in the V-Ohm meter input
Measure between one of the AC inputs and the + and - terminals on the bridge, measure what the meter reads then reverse the leads and take the same readings.
#49
Without touching anything, the meter reads 1
When I touch the probes to the tabs, there is no changes, when I cross the probes w/o touching the rectifier, it goes down to 0.00
#50
Your 0.00 reading means that that leg of the bridge is shorted out.
#52
Joe, that's when I touch the probes together, I am not touching the BR
I move the probes around trying various positions and the meter never changes from 1
#53
You are measuring in the wrong place Ron. Measure from one of the AC marked terminals and the positive terminal both directions, then do the same for the negative terminal and that same AC terminal.
Then move on to the second AC terminal and repeat the drill from above.
There should be 4 groups of readings, with 2 readings in each of the 4 groups.
#54
did you try you meter on a good diode? Like one of the small diodes on the control board?
#55
499
482
496
481
That's it, no readings in the other positions
#59
The readings are a lot lower then what you mentioned Joe, I think I would rather just get a correct one
Can I go ahead and plug this in and see if it blows the fuse? Do I have to reinstall the BR first or can it be left off?
