Brettl
Rebuilding an older unit looking for an original board. Please email me if you have one
Thanks, Brett
artvandelay1@comcast.net
			Thanks, Brett
	Close to the Bias and protection circuit...
I see the protection transistors are NTE....they're a crapshoot. And you did try powering up?
I only plugged it in standalone Lee, no meter lights came on so I figured it needed to be gutted anyway
What do you mean by shotgunned Joe? I see no holes blown in the board LMAO!!! Just those two areas I imaged looked bad under the magnifying glass
	How do you test the tranny to see if it's good? I have a digital meter finally. What setting do I use and what are the test points for the bridge rectifier? Which hole do I plug the positive probe into on the meter? There is 2 besides the common ground (black)
It toasted the power line fuse instantly, the speaker line fuses were fine
Remember, it's gutted now
That is not a stock bridge rectifier, someone has replaced the original.
