- Jan 14, 2011
- Gillette, Wyo.
Cool !!!! Should have mine in a few days Lee !!!!
yOUR WHAT hILLBILLY?? yOUR aCURUS?? That one you found for 250.00??
I like noise levels like that - inaudible. Since it has no phono section, do you not bother with vinyl or do you use an outboard pre with this Acurus? Maybe a different pre all together?
Could be wrong, but specs I recall were numbers published while using phono inputs. I guess since the proliferation of line level jobs, pre-amp noise floors dropped like a stone.
Can't get no table for my records
Ain't got no needle for my grooves,
Ain't got that fancy spec,
On my new pre-amp
Ain't got no antidote for you....
No.... The one YOU found me for 250 .... He called today and I missed his call... To late to cal back once I saw the call... He knows I want it !!!!yOUR WHAT hILLBILLY?? yOUR aCURUS?? That one you found for 250.00??
Other measurements......Utterly awesome...
That'd an unweighted spec. See if the Perreaux is weighted
It's cool that they list both...
Why is the A weighted figure lower Lee?
