- Jan 14, 2011
- Gillette, Wyo.
Phase distortion because of the sampling rate?
exactly LeePhase distortion because of the sampling rate?
It might also have something to do with how I have things set up through my pre-pro. I guess that my Sherwood Newcastle P-965 processor is getting a little technically "old". Maybe I am better off going analog out to the pre and letting the players DAC do the D to A conversion? Or am I better off using a coaxial digital connection..and letting the P-965 do the D to A ? My SACD players are probably as old as the Preamp, so maybe it's time to upgrade? But, the SACD itself is as old as both of the components.. What is the best way? And are we talking stereo anyway, or 5.1? The Oppo is 32 bit I notice, so what are you using as a processor, the Oppo? and running in stereo?
I see that the Oppo uses the new 9018 asynchronous chip. I've read about it...but again, it's all in the implementation of that chip as well, and it sounds like Oppo got it right in the 95. I guess there is something to upgrading your sources to the latest and greatest. Just when you think it's safe to go back in the water..........
I took the bottom plate off and doused the switch with DeOxit...and no change. I will pull the amp and try to see if the bracket is holding the meter too tightly. Do you want pictures of the switch? The meter? Or anything else? I'll do it today. The meter does swing with static electricity...when I tap on it, but doesn't move with power...so I don't know that it is "in a bind" from the bracket...but I'll pull her out and take the face off...
It sounds so good, I LOVE it...sounds like a fully comp 400 with twice the power!!! SWEET...
