I used part of it for the ground to the DC protection board- looks like I screwed up in the wire allocation...
I need to find another 20" of the 18g wire. Should be commonly available, right?
no pm me your address Mark
Ne'er mind- gotta workaround. I'm good!
DAMN that shit's expensive!!!
No need to check both bias points. The control boards came out before the backplanes and Joe being Joe......
I plug the dbt into the variac. You're right about it not making sense otherwise. 145k between collectors and ground is about right. Does that figure climb steadily?
You've checked the power supply and all is well?
BTW - I've enjoyed your videos so keep them coming.
The bass is the reason I didn't keep the amp. It exhibits less control over the lows compared to a WOPL...I guess I'm just spoilt...
...they just didn't sound that remarkable.
Amen Scott, that was my basic assessement....
On on your AC run along the top, that is the best place for them. DO NOT TYWRAP THE SIGNAL INPUT WIRES TO THESE AC WIRES. Rather TYWRAP the AC wires together and keep close to the chassis bend. TYWRAP the signal runs and form them to exit directly toward the front panel and then down to the controls.
Got it?
Yes Mark
PL violated their normally white ground scheme when they connect the meter works. This has been violated on the Series 1 amps with analog meters too.
Welcome to PL's world.
