- Apr 17, 2014
I bought it for $40, blowing fuses. I thought it'd be an easy fix -- replace the bad power transistors and go.
Unfortunately, that's not the case. I kept blowing B+ fuses on initial power up, even with the output transistors removed.
Pulled ALL of the output transistors, pulled both channels, and replaced every single transistor on both boards with parts from a kit off of eBay. Most of the diodes too.
I attached one channel, no output transistors installed, and powered it up. R12 fried immediately.
I can't even get it working to the point where I can test voltages to try and see what is wrong.
I'm beyond frustrated with this thing, and I'm ready to use it for target practice.
Charles.
Charles.
