Well after messing around with this little unknown ts200 phase amp for a few days now, I found that is has one dead
channel and the other doesn't sound too bad but in orde to repair this its going to take alot on un-soldering just to
get to the parts. I'm not that interested in doing any of that now, so into the broken pile it goes for the time being.
I was mainly just curious if it could have been a proto type. maybe the answer will surface later.
So I decided to move on and test the first of the two big amps. This PL700 SERIES II is the one Ed rebuilt and converted it
to full comp. Its a beauty. I check the DC (- 1.75mv left & 5mv right), brought it up on the variac slowly and all good.
Hooked it up to a known good preamp and a couple of small bookshelf speakers for a listen via cd player with a little
Diana Krall.
The common turn on current rush blew the speaker fuses (2amp) instantly! So left it as it was, replaced the fuses and
brought up the gain and the preamp volume.
THIS AMP SOUNDS AMAZING ! And quiet as a mouse.
What do you think I should do next? If anything. Joe? Lee? Add the WO board to rid the turn on rush? And is the board compatable
with Ed's full comp conversion?
I don't want to hook it up to the Dahlquists until I'm sure it won't start taking out fuses at start up. Mine are mounted
8 ft high on the walls like studio monitors at the moment. Pain to change fuses.
Man its nice to hear a Phase again. And I have two more waiting for the final system when the man cave room is done!
Jm
