JustMike
Today I had a chance to look at this little amp from the Phase stack I received . It appears to be a one -off build, possibly
the prototype for the Pl200 series1 amp.
The cage is all made from perf metal. Has a aluminum back and front panel. On the front lower left someone etched
in: ReisE 5080Q (WAPL) On the back in has the TS200 I.D. in screen or transfer letters. The sides are made of wood
and finished quite nice. On the front is a little Phase Linear sticker hiding two additional holes that were drilled for some
reason or part.
I went ahead and brought it up on the DB and Variac. (I did check fuses first and they were Aok.)
then I check the DC on each speaker outputs and if I did it correctly, it does not look too good.
Left Channel : 2.6mv
Right Channel 131.2 mv.
Sorry for the crummy photos, I got to ask Santa for a good camera.
What do you all think I have here ?? and what should I test next
Cheers,
Mike
reason or part.
Cheers,
Mike
