- Jan 14, 2011
- Gillette, Wyo.
We have run into a snag on the backplane installation. The chassis appears to bo not as tall as the "B"s"......Whether it was bent in the wrong place , I dont know. The platic bushings are tight up against the lip , but they did go. The holes must have been slightly undersize also as the bushings had to be exactly straight to go. A couple took some rotary motion to go, hence the seal pic.. It looks like a trip to the shop belt sander is in order.......
Question Sir Joe.....how much material can i take off the top or bottom of the backplanes?? I only need .010-.015 total....1/2 off the top and half off the bottom...
