yes..."inherent in the desgn" i believe were the words... and "NOTHING CAN BE DONE ABOUT IT"
gadget73
I guess both of the ones through here were broken. Either that, or someone had already taught them the words.
P.L.F.
I love BIG amplifiers!
My first horn speakers arrived!
Here they are - Yamaha S 4115H series I, see the pics encl. (http://www2.yamaha.co.jp/manual/pdf/pa/english/speakers/S4115HE.pdf). Perfect shape for their age. I'm the second owner after a Swiss farmer, who locked them in a storage room for more than 25 years. They sound surprisingly live and musical. Downside is the woofer power, but there are perfect and 'Yamaha approved' Eminence subs: https://www.parts-express.com/eminence-kappa-pro-15lf-2-15-cast-frame-driver--290-420 .
THEY ARE WAITING FOR LEE'S CONVERSION PROJECT although probably won't be ready to meet WOPL max power...
I'd need to clean them, check/upgrade the x-overs and replace the speakers' posts.
Any advice how to clean the aluminum HF horn throttle and those lovely white cones from small bug stains? Should I re-paint them :)?
Thx!
P.L.F.
Yamaha S 4115H from inside
As I expected, he cabinets have never been opened. I looked inside - could not resist... - and took some pictures. The x-over seems to be in a perfect shape, no need to upgrade I suppose. The two drivers are original, but there are aftermarket / new subs available at simplyspeakers.com (HF drivers) and parts-express.com (LF woofers) made by Eminence in case of WOPL amp accidental overloading. What I don't like is the damping material on the back cabinet's wall. Have to think what istead...
My 'cleaning questions' of on of previous posts still without any advice :hello1:.... ?
Looks like a nice cast frame on the woof. Don't know what to say about cleaning the aluminum horn though...
JustMike
"wherever she lets me"
"Just Passin thru"
Hello Przem.
There are products available for cleaning Aluminum mag wheels. These are spray and rinse chemicals .
Check your auto parts stores.
the best method to bring back to like new would be to have them blasted in a sand blasting cabinet but not with sand.
Walnut shell or baking soda is the blasting media to use, or plastic bead which is a little more aggressive.
Look for someone in your area under auto restoration.
P.L.F.
Hello Przem.
That's it - auto stuff to clean Alu wheels...! Thank you :blob8::blob8::blob8: !!!
