avionic
I find a flat bladed exacto knife, like a chisel tip works great for scraping the glue remnants off the PCB.
I thought you stripped the PCB completely and used your 30 ton press?
Do you folks make your own wire jumpers or do you buy them from one of the electronics suppliers?
A while back I picked up a resistor "grab bag" on ebay for a couple dollars. Thats what I use for jumper wires. I just snip the leads off the resistors.Use the leads and shit can the 50megΩ resistor.Do you folks make your own wire jumpers or do you buy them from one of the electronics suppliers?
You can make your own depending on what type of jumper you're referring to. If it is a jumper on a circuit board you can use bus wire with Teflon sleeving or bus wire that comes with insulation from the manufacture. The gauge is dependent on what you intend to jumper.
This.
Actually, I generally save the cap leads after installing them and use them for jumpers as needed.
18 picofarad +/- 5 % tolerance
180----capacitance
J------ tolerance
http://www.electronics2000.co.uk/calc/capacitor-code-calculator.php
http://www.mouser.com/ProductDetail...inVFKM98vCmggniHpDuVtAtJd01FxsXqasV82tHH55A==
