- Jan 14, 2011
- Gillette, Wyo.
Hmmmm.....
Agreed, and I think it all comes down to how the speakers react with the room they're in. The room really becomes an extension of the speaker.
... yes, that goes without saying. no amount of room treatment, without totally killing the room will separate the two.
the only way to hear the true speaker is in the middle of a field....
sometimes, when horns are bit overpowering, it helps to try and tilt the whole thing back and try and focus them just a little above ur head. that works great, until you stand up, then u end up thinking, .... damn that doesn't sound too bad either, and u end up dropping 'em back down again. sometimes u just can't win.
but that's half the fun of it.... LoL
I don't find myself wantin to move my K's much....what makes or breaks a horn loaded system is the mid-horns.. and in that regard , for the levels I prefer thre is no choice but to spend a lot of money on mid drivers and wood horns. A bad one will drove you from the room, a really good one will keep you glued to your seat....it's that simple...
True , BUT the quality of the driver and construction of the horn itself can still be responsble for making a mad dash for the door.....but when it's right....it is SOOOOOOOOO good.
BD, with Tim's Soniphase he built the mid and tweet stack identical to the K's mid and tweet stack. The bass bins are front firing folded horns. We've left the tops unattached and move those in/out and tolt up/down and mess with the angle of the faces quite a bit and the sound can be manipulated a bunch. And like ya say, one day it sounds good and other days it don't. We used the same crossover as the K's and that wasn't exactly what it needed either. The Soni's have an 8 ohm EVX-155, the K's a 4 ohm Crites 1526S.. After talking with Joe because the EVX didn't sound right to our ears it was determined that the inductor for the 8 ohm EV's had to be doubled from the 4 ohm Crites. The new inductors have been shippe and shoulkd get em in a week or so...
Well it wasn't obvious to me that you needed a different inductor for an 8 ohm woof compared to a 4 ohm woof. That's how little i know about speaks and crosses.
Went to another concert at Red Rocks, the had the Nexo horn array up as the first ones. The bass bins were not as good as Shpongle , and not near enough of them. I gotta say those Nexo's are amazing...
That is a great point, I guess I've never heard (in a home system) a really, really good horn system. I did hear a pair of K's in a high end store about 15 years ago, with Levinson mono block amps. I forget what the source was, but I recall being unimpressed. Especially for $35K mono block amps, wired to 220 volt mains. I remember thinking that they had really blown it when they set the system up, because the K's were NOT in a corner. The mids were crashing through and everything was unbalanced. The bass sucked.I don't find myself wantin to move my K's much....what makes or breaks a horn loaded system is the mid-horns.. and in that regard , for the levels I prefer thre is no choice but to spend a lot of money on mid drivers and wood horns. A bad one will drove you from the room, a really good one will keep you glued to your seat....it's that simple...
So ...what are they actually made of??
The only other K's I've heard was at a party 35 years ago, and I can't remember what the system consisted of, but I remember that I was very, very impressed with it. Those were in the corners, by the way.
I guess I prefer standard (non-horn) drivers because they're more forgiving. I think my DQ-10 system sounds ideal, because when the music is IN-YOUR-FACE that's what they deliver. Grab your seat, in your face. But they image so well, and there isn't any beaming of any frequencies. They are balanced IN MY ROOM. In your room, they might suck.
The KG-4 speakers I had absolutely rocked out in open air. They had room to breathe, and they sounded very, very good. I remember thinking how I wish I could have gotten them to sound that good inside. Now I've got that kind of performance in spades with the DQ-10 speakers augmented with two Dahlquist low frequency modules, driven by 2KW of WOPL glory. Took a while, but my listening room finally gave in and it sounds just the way I want it to now. And that's what this wonderful hobby is all about, right?
plastic, with a pair of 8" speakers firing forward (and one firing backwards to cancel out rear radiation and so feedback on stage when the front pa sound couples with the onstage monitor sounds), with a small horn between the two forward firing ones.
nothing special.
it's wot they gain by being a line (array) that makes 'em couple and so increasing the spl.
What do they run for horns?
