62vauxhall
- May 14, 2014
- Southwest Kootenays BC
Check fuses gary...
All fuses are good.
Check fuses gary...
The collector should be isolated from ground by the mica isolator / Sil-Pad.
Good point, did not think of that.
Get zero - to bus bar or chassis.
Ok, drop all 4- 5 amp rail fuses, turn it back on , all the way, then check each post in the rectifier...ac fot the ac of course and DC for the DC...
You did have the grey sil-pads under the 410's????????
God, how did I miss this...Gary is that zero ohms, or OL ??
That was ZERO ohms and fuses were in.
Yes, but reference ground at the bus bar and check all 4 posts, also was the ground check result on the 410 case zero ohms or OL?
Pull fuses.. recheck. If you still have zero, insulator breakdown... or those 4uF caps that go between the tie points (the pos and neg rails) and ground. Or a cat whisker wire ya can't see yet...![]()
No minus volts on one of those posts ?? Check that 410 case now with no fuses in....
Fuses are out still get zero OHMS.
4uF capacitors????
tomorrow durung the day I can fire up my air compressor and blow out any debris. I live in a second floor condo and think running an air compressor after 7PM contravenes some strata rule.
Jer is referring to the caps on the back wall wher those pesky diodes are, yours are .33uf I believe...
