- Jan 14, 2011
- Gillette, Wyo.
OK.....
A D-500 is the same style as a Ser II, but they bumped the rail voltage to get 500 watts a side out of it.....not a paragon of quiet, and it had a 2 stage power supply and was way more complicated thatn it had to be, but that was quite awhile ago....and a bitch to work on....Ed tells me...
Gonna head to my buddy's house and try this wax he's raving about. I'm not a wax or oil fan really.
It' about 9 am in Warsaw. What a nice 'good morning' seeing my baby is so well taken care! In case of amps the feeling is normal I believe... ? Yes, probably only in case of amps...
As you see the output stage is still original in quasi- comp. topology. The driver board was recapped and most fatigue resistors replaced. Power supply caps were replaced too. DC protection added plus a bit rewiring done as per Don's recommendations. Less hum afterwards. RCA and speaker outputs replaced. If I remember the amp had very low DC - a few mV each channel. BIAS set about a year ago or so.
Sonically in a couple words - LOT's of power and I like it as we all do. Trully driving emotions. But I was missing sound stage dimensions and details a bit - can compare with another PL700II running fully comp. stage with Burr Brown OPA134 on the entirely renovated PL-36 driver board (almost all parts relaced). That other gear sounded much better.
Glad Lee checked data at the project starting point. I am very curious the final result!
A fantastic project for me to be in by all means!!!!!!!!!!
Dare I ask what the wax is for?? You've got me a bit concerned Jase. Oil or wax - really?????????![]()
Thank you Lee. The box used to be a part of US Army equipment. Bought it at local flee market. The seller didn't tell me exactly what was usually inside. Some kinda rocket radio remote steering or so?Had to be rubust for sure. And perfectly well fit for heavy transformer PL700 chassis! Reasonable price and very solid packaging for the purpose - it costed less than 30 bucks...
Lee's gonna hook you up - this will be an interesting thread for more than one reason.
LMFOAO!!! Jase, you know me soooooo well already..
Rail voltage is 108.3, no wonder she's a HOTTIE!!!! This amp is definately a she, she talks to me...she's tellin stories Przem, you scoundrel.....
Rail voltage did NOT GO BELOW 94.3........compared to 79 on Jases.....I would love to take this one to max on 4 , but the LED driver is a now obsolete IC. Have a call in to Ed to see if a major disaster at 4 ohm maxout would trash that particular IC...
The Ed phone call is ended, they can take awhile sometime and I enjoy every second, anyway, he sees no problem....even told me how to isolate the meters should I be a wee bit trepidacious....
