- May 14, 2014
- Southwest Kootenays BC
Ya know what Gary, desolder that whole board in preparation for the new one, study the PL20 wire hookup diagram in the Archives.. After you get the board out ya need to check all board wires going to the backwall for shorts again. Can you borrow a Variac?
I'll take the board out and keep a PL20 hookup diagram on standby. In 25 words or less, what's the difference between it and a 14A from a benefit standpoint?
Once it's out, I'll look through those wires for shorts.
I was told a few weeks ago I might be able to acquire a variac. I'll pursue that and if successful, will get one this Sunday, even if it's a loaner. 10A, right?
I'll post again once I have it but may post sooner if I observe anything suspicious or blatantly obvious with the wires.
Also, before I forget, I asked about the sheilded cable coming from the volume pots. I think you said "start over". Were you meaning replace the cables as I proposed or continue to use the existing cable, cut the ends, and make new connections?
