To monitor bias you hook your meter leads on either side of the 10 ohm resistor on the backwall on the positive drive side(the left)...and then adjust the pot...
62vauxhall
Southwest Kootenays BC
Thanks, sounds easy enough. Hook a meter lead to each side of the 10 Ohm (brown/black/black) resistor in the left side column of output transistors.
Correct Gary, remember let the caps bleed, a slip of the probe there and we'll be at this for another month....
OK, now we check bias, on both channels to make sure the outputs are turned on then we go from there...
