- Jan 14, 2011
- Gillette, Wyo.
No Gary that's fine, just check on each side of the 10 ohm so we see where were at..
No decimals in the 121 minus voltage??
Nav, if you've got some advise, let's hear it....
Try adjusting bias on the left channel, see if it has an effect...
I'd put a 20 to 50 ohm 5 or 10 watt resistor in series with the alligator clips to bleed down the reservoir caps.
Are Q5, Q7, or Q10 getting hot?
Those are perfect Gary, use a resistor in series with the jumper between the +/- cap studs to bleed them faster...
Best I've got are (2) 10 Ohm 10 Watt. I'd have to get the ones you specify tomorrow morning. So one per alligator clip?
OK, for the negative lead hook it to the copper bus bar for a good ground, we are going to check the low voltage supplies for Q1-Q4.....the negative can be a gripper, the positive heeds ri have all but the last 1/16 " of probe covered..
And that's only to bleed the caps when making a connection to check voltages in a bad place to slip a probe, like on the ack wall.
For now , hook up the hegative lead to the buss bar,turn the amp on and VERY CAREFULLY check what the voltage is at the emitter of Q1 left and right and tell me what ya got...
