Why of course, and wouldn't have it any other way!!
And it's still bent Joe....
Yes it is Lee but not for long...
Ok guys, when we backed up Jani's computer yesterday it took forever and when we open the external hard drive to check what it has done it saved all the files in "Word" about 2 gigs each and when you go to open them up it says it's too large a file for Word to open.....WTF?
Ot's a Simpletech xternal HD with StorageSynch backup software. No, that's for mine hers is a newer version but does the same thing. Mine made a mirror copy, hers just made 2 gig Word files out of everything. Probably a settings screwup on our part...
Backup software packages come and go so it is hard to keep up with them.
Check her backup settings. And try backing up just a few files, and then make sure you can access them on the exterbal drive.
I mysel just use a big ass usb drive and just drag and drop the files I want to backup, thay way there is no file reformating or compression going on and the filen the external drive can be opened by any computer anywhere ithout any special software.
I guess it depends upon what and how muvh you are backing up. I only keep copies of date files, as the software and applications can always be reloaded in the event of a hard drive failure.
Jer is now busily transfering stuff to her new computer and there is cheering in the house!! He's completely done with mine and the hookup to the tunebox is done!!
Jer's not onlyg ood , he's fast.
And he now knowss how to make jello shots...
I noticed he didn't make any comments on the favorite for DancingBear.com.![]()
