- Jul 6, 2010
- Broken beyond repair but highly affable
dont mess up our post to watt ratio lol![]()
Would that be a PiMPO rating?
Finally got the AC run (blue and white wires ) and figured out what I want to do with the rest of em...
Is it just setup diff then other 700's ? Is that why you have to figure out the wire route. Or is it something you've been trying to do for awhile now?
Wott watt radio ratio? Whatever it is wopl it.![]()
One watt per post John.......
applying halfbiass Times 2 (for the 4 ohm factor) Two Watts
Is that RMS or peak?
At the rate were going were looking at the 8 ohm post/watt ratio but if it takes to long we might hit the 4 ohm lmao
If we get past 774 posts Lee will just have to keep on modding till he can make the output match the post count.
Jase, it's basically being able to use complementary outputs , the MJ21195, MJ21196 pairs as opposed to running all MJ 21196's and using a phase inverter in the driver. It's more symmetrical on output, better voltage balance , better distortion and bigger soundstage........not much.....
The big black wires on the BR are #12 silver/teflon (thanks Navo) this is a first for that position....
Silver/Teflon wire?
