Skynyrd77's Thank Godamighty , Finally My Own WOPL Build Thread!!
The subject in question is under interrogation, not faring well either. Under only 8 ohm duress, it's story starts to change at 100hz, this is bad, way bad. I have changed out thge 5 amp rail fuses for 10 amp, time for a little water boarding....
This FR stinks... at 10 hz it is down 3-1/2 decibels......that means it is half as loud at 10 as it is at 100 hz. A typical WOPL it is only down . (yep that's POINT) .15 db, doubt if you could tell the difference from FLAT...
I ran a video hoping for some excitement, but no. Started to clip at 305 into 4 ohms. This puppy is sick. We'll try 8 ohms and see what happens...
Lee: It appears you will have to really work this one to maintain the prestige of the Phase Linear WOPL moniker. Nice to see Jason get a deserving amp with all those good tunes he has been collecting.
Like you've never seen or felt pressure in your life. You haven't broken, yet, and you seem to thrive on a challenge.
Blessed are those that are meek...and you need to get that amp in less-meek-mode. Meekness doesn't get you laid. And Jason needs an amp with cajones.
No prawns this week, Too busy at work.
Oh, I thought you set traps and picked em up as you came home...
Ok, am now plugged in to the RACK power circuit, see what happens. The 14 gauge , 50 foot exrension cord was not getting it....
True, but I don't work on Sunday, Monday.
She's a hottie!! 106 on the rails, checcking for voltage sag while we take it up.....um....Joe anything you want to try in destruct mode??
Guys, Big power circuits make all the difference in the world. Clipped at 501 into 8 with rail voltage holding at 90.6....
You are the destruction master Lee...
I just help clean up the mess with you afterwards :-)
Dayam!! I missed this post, most excellent Father...
